tribble121
#1 Posted : Thursday, December 27, 2007 1:28:43 PM(UTC)
tribble121
The Diswasher Will Not Pump Out The Water
misterfixall
#2 Posted : Thursday, December 27, 2007 3:30:43 PM(UTC)
misterfixall
first of all remove dishwasher drain hose from under sink counter. push screw driver into drain nipple to unblock , look into hose end to see if its clear .put hose back on +try cancel drain again +see what happens. if it does not drain remove kick plate , remove hose from drain check valve attached to motor on right side .un thread drain check valve .+remove check for crap inside ,reinstall valve tighten snuggly .do not over tighten,replace hose ,try again
Whirlpool Washer agitates on all cycles but will not pump or spin (Washer Repair)
by PecosBill 1/19/2015 7:31:02 PM(UTC)
Kenmore will not pump water out (Washer Repair)
by funday 7/27/2012 8:06:07 AM(UTC)
Will not pump water or spin (Washer Repair)
by TheGreens 3/21/2012 11:26:50 AM(UTC)
dishwasher wash pump will not pump (Dishwasher Repair)
by streetguy 1/18/2011 8:19:52 AM(UTC)
washer will not pump water (Washer Repair)
by sleepster69 4/6/2010 1:21:58 PM(UTC)
GE top load washer will not pump out water (Washer Repair)
by cluelessdave 1/29/2010 10:53:29 AM(UTC)
GE Triton XL will not pump water in (Dishwasher Repair)
by xfeejayx 8/1/2009 9:16:14 AM(UTC)
Washer will not pump out water (Washer Repair)
by woodworkingdan@sbcglobal. 3/26/2009 8:41:44 AM(UTC)
will not pump water out of tub (Washer Repair)
by mckee 3/10/2009 7:25:06 AM(UTC)
Washes But Will Not Pump Out Water Or Spin (Washer Repair)
by SHARON MARIE 79 11/3/2008 7:46:42 AM(UTC)
