funday
#1 Posted : 13 years ago
funday
All cycles work until it is time to rinse where the water is pumped to the drain. Manually pump it out possible to do the laundry. Appreciate some insight and also where a manual may be found. Thanks. Likely very important, washer used to work somewhat fine as is plugged into a GFI and would pop out when the rinse/drain started, reset GFI and eventually get through the entire cycle, plugged into a regular outlet 20a and worked fine a few times and then this issue.
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Open the control panel check the continuity between two outer wires at the lid switch plug. with the lid closed you should read continuity.
No continuity - replace the lid switch Part number: 3949238
Use the video clip for disassembling instructions.
Thank you. Post the results.
Simon.
funday
#3 Posted : 13 years ago
funday
Simon, your reply is unbeatable, the video makes this job exceptionally easy.
while I am heavily trained in construction as a PM over huge projects, this washer issue would have ended in being junked, myself flipping out in attempting it and requiring a 12 pack to calm down. Count on any issues I have and the parts needed coming from your business. Thanks I truly appreciate a professional who is a real professional. DWC
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Thank you. I'm blushing.
Simon.
