tribble121
#1 Posted : 17 years ago
tribble121
The Diswasher Will Not Pump Out The Water
misterfixall
#2 Posted : 17 years ago
misterfixall
first of all remove dishwasher drain hose from under sink counter. push screw driver into drain nipple to unblock , look into hose end to see if its clear .put hose back on +try cancel drain again +see what happens. if it does not drain remove kick plate , remove hose from drain check valve attached to motor on right side .un thread drain check valve .+remove check for crap inside ,reinstall valve tighten snuggly .do not over tighten,replace hose ,try again
Whirlpool Washer agitates on all cycles but will not pump or spin (Washer Repair)
by PecosBill 10 years ago
Kenmore will not pump water out (Washer Repair)
by funday 13 years ago
Will not pump water or spin (Washer Repair)
by TheGreens 13 years ago
dishwasher wash pump will not pump (Dishwasher Repair)
by streetguy 14 years ago
washer will not pump water (Washer Repair)
by sleepster69 15 years ago
GE top load washer will not pump out water (Washer Repair)
by cluelessdave 15 years ago
GE Triton XL will not pump water in (Dishwasher Repair)
by xfeejayx 16 years ago
Washer will not pump out water (Washer Repair)
by woodworkingdan@sbcglobal. 16 years ago
will not pump water out of tub (Washer Repair)
by mckee 16 years ago
Washes But Will Not Pump Out Water Or Spin (Washer Repair)
by SHARON MARIE 79 16 years ago
