soulgong
#1 Posted : Thursday, December 27, 2007 12:39:59 PM(UTC)
soulgong
My Frigidaire Gives Me An Error Code F30 Can You Tell Me What This Means.
misterfixall
#2 Posted : Thursday, December 27, 2007 6:37:56 PM(UTC)
misterfixall
are you sure its not f3 .if so it temperature sensor in oven .long probe usually on left upper .
soulgong
#3 Posted : Sunday, December 30, 2007 3:45:06 AM(UTC)
soulgong
no it says f30 & another thing i cant set the clock would the temp sensor affect this?
Admin / APP Team
#4 Posted : Sunday, December 30, 2007 3:05:33 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
You have been a member since:: 7/18/2007(UTC)
F30 is one of the new error codes that were introduced by Frigidaire a little while back.
Here is the explanation (courtesy of appliance aid):
F30 - Open probe connection
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
*RTD scale is available at applianceaid.com.
