My Frigidaire Gives Me An Error Code F30 Can You Tell Me What This Means.
are you sure its not f3 .if so it temperature sensor in oven .long probe usually on left upper .
Originally Posted by: misterfixall are you sure its not f3 .if so it temperature sensor in oven .long probe usually on left upper . no it says f30 & another thing i cant set the clock would the temp sensor affect this?
Rank: Administration
Groups: Guests
F30 is one of the new error codes that were introduced by Frigidaire a little while back. Here is the explanation (courtesy of appliance aid): F30 - Open probe connection 1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector. 2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. *RTD scale is available at applianceaid.com.
