Whirlpool model ED2VHEXVB01 side by side with same issue. drain pan is dry, defrost tube is clear. it occurs every 2-3 days. we only use cubed ice.
Lola, the drain on mine is at the bottom, behind a drawer.
I'll try turning off the ice maker and see if it stops.
We'll try again when we go back to our vac. home in a few weeks. Thanks for your help! Lola
I didn't ask you if you ever got yours to stop leaking and if so, how?
Not yet, had another "episode" last night. I'm going to try turning off the ice maker for a while once its full.
The issue on mine turned out to be the defrost evap. tray was cracked in the front corner under the filter cartridge. I think the filter sagged down and the weight caused the cheap thin plastic tray to fail.
