2 Pages<12
Andyman
#11 Posted : Saturday, February 14, 2015 10:49:06 AM(UTC)
Andyman
Whirlpool model ED2VHEXVB01 side by side with same issue. drain pan is dry, defrost tube is clear. it occurs every 2-3 days. we only use cubed ice.
Lola, the drain on mine is at the bottom, behind a drawer.
I'll try turning off the ice maker and see if it stops.
Lolajohnson
#12 Posted : Monday, February 16, 2015 7:35:55 AM(UTC)
Lolajohnson
We'll try again when we go back to our vac. home in a few weeks. Thanks for your help!
Lola
Lolajohnson
#13 Posted : Wednesday, February 18, 2015 8:35:02 AM(UTC)
Lolajohnson
I didn't ask you if you ever got yours to stop leaking and if so, how?
Andyman
#14 Posted : Thursday, February 19, 2015 3:23:46 AM(UTC)
Andyman
Not yet, had another "episode" last night. I'm going to try turning off the ice maker for a while once its full.
Andyman
#15 Posted : Saturday, July 11, 2015 9:15:50 AM(UTC)
Andyman
The issue on mine turned out to be the defrost evap. tray was cracked in the front corner under the filter cartridge. I think the filter sagged down and the weight caused the cheap thin plastic tray to fail.
Guest (5)
Whirlpool intermittent water leak (Refrigerator & Freezer Repair)
by UnclePen 9/26/2015 3:06:44 PM(UTC)
2 Pages<12
