dryer quit after it had been on about 6minutes tried push to start switch and it didnt click could this be problem
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: eula  dryer quit after it had been on about 6minutes tried push to start switch and it didnt click could this be problem First thing you want to do is flip the breaker off and on for the dryer a few times to see if it is tripped. If you have a meter check the power where the cord goes into the back of the dryer. The other 2 things it could be is the door switch or thermal fuse. It is usually the thermal fuse.:cool:
