eula
#1 Posted : Monday, June 22, 2009 8:23:04 AM(UTC)
eula
dryer quit after it had been on about 6minutes tried push to start switch and it didnt click could this be problem
#2 Posted : Tuesday, June 23, 2009 1:48:19 AM(UTC)
Replacement parts for WHIRLPOOL LER7646EQ2 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406692.pdf
Did the unit restart when you let it cool down or is it still dead?
I doubt it is the push to start switch.
More likely bad power or the thermal fuse.
kayakcrzy
#3 Posted : Tuesday, June 23, 2009 4:13:36 AM(UTC)
kayakcrzy
First thing you want to do is flip the breaker off and on for the dryer a few times to see if it is tripped. If you have a meter check the power where the cord goes into the back of the dryer. The other 2 things it could be is the door switch or thermal fuse. It is usually the thermal fuse.:cool:
Whirlpool LER7646EQ2 drum roller banging noise (Dryer Repair)
by ultrachrome 3/6/2022 1:03:29 PM(UTC)
model ler7646eq2 ele dryer won't heat (Dryer Repair)
by dave3795 11/18/2011 7:37:13 AM(UTC)
