PFD542
#1 Posted : Saturday, December 10, 2011 2:26:44 AM(UTC)
PFD542
LG gas dryer DLG2241W
Gas Inlet Valve Assembly 5221EL2002A
Converting from NG to LPG.
Have LP orifice 4948EL4002B.
After changing orifice, instructions state "Adjust the regulator adjustment screw down to the closed position"
I need a better explanation:
The large white plastic screw has a thin nut at about the middle of its exposed threads with a blue liquid (Loctite?) dabbed on it. Do I screw it down till this thin nut touches the brass part and stop there or what?
How do I know if this is correct.
ApplianceJunk
#2 Posted : Saturday, December 17, 2011 10:08:29 PM(UTC)
ApplianceJunk
Maybe this video will help show you how.
LG Gas Dryer LP Conversion - YouTube
PFD542
#3 Posted : Saturday, December 17, 2011 11:20:43 PM(UTC)
PFD542
Thank you!
ApplianceJunk
#4 Posted : Sunday, December 18, 2011 5:03:14 AM(UTC)
ApplianceJunk
Your welcome.
Happy Holidays
Old Hardwick Gas Range LP conversion and/or adjustment (Oven Repair (including Ranges and Cooktops))
by DaveLab 5/28/2024 2:53:48 PM(UTC)
LG DLG3601W No Working after LP conversion (Dryer Repair)
by Techmotivated 5/1/2024 2:57:27 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Thermador range NG to LP conversion (Oven Repair (including Ranges and Cooktops))
by BadgerBlues660 2/28/2019 4:18:28 PM(UTC)
thermador LP conversion info needed .... (Oven Repair (including Ranges and Cooktops))
by ertech 11/24/2018 4:21:56 PM(UTC)
LP Conversion from NG (Oven Repair (including Ranges and Cooktops))
by detill@bellsouth.net 9/14/2015 5:43:02 AM(UTC)
Need LP conversion kit needed! (Oven Repair (including Ranges and Cooktops))
by wickcheed 7/21/2015 2:13:29 PM(UTC)
LP conversion kit (Oven Repair (including Ranges and Cooktops))
by ANiforos 11/5/2013 5:34:24 PM(UTC)
LP Conversion Orifice #'s (Oven Repair (including Ranges and Cooktops))
by airbiz 11/15/2012 10:02:02 AM(UTC)
NG-LP Conversion Kit (Oven Repair (including Ranges and Cooktops))
by Nora Hess 8/9/2012 3:54:38 PM(UTC)
GE LP conversion for oven & broiler (Oven Repair (including Ranges and Cooktops))
by keyserp21 7/17/2012 9:16:36 AM(UTC)
Nat to LP conversion (Oven Repair (including Ranges and Cooktops))
by regie 8/26/2011 12:45:28 PM(UTC)
No heat after installing LP conversion kit (Dryer Repair)
by kenokagi 7/10/2011 4:37:56 PM(UTC)
lp conversion kit instalation (Oven Repair (including Ranges and Cooktops))
by snarvaes 2/28/2011 3:04:07 PM(UTC)
Dacor ng to lp conversion ESG366 (Oven Repair (including Ranges and Cooktops))
by rryan1764 7/27/2010 2:19:17 PM(UTC)
