ramrod
#1 Posted : Sunday, June 21, 2009 7:49:57 AM(UTC)
ramrod
Have an Admiral washer which pokes holes in my clothes. Had someone out a few years ago who said it was from plastic that is at the bottom of the agitator. The problem is getting worse and we all have small holes in our shirts. Any suggestions on how to fix this?
sidfink43
#2 Posted : Monday, June 22, 2009 5:49:17 AM(UTC)
sidfink43
Sounds likely to be a replacement of the agitator, but I cannot give you more info without a model number.
If you post a model number we can show you the parts diagrams.
ramrod
#3 Posted : Thursday, June 25, 2009 7:49:25 AM(UTC)
ramrod
I have an Admiral AAV7000AWW. Thank you for your time.
sidfink43
#4 Posted : Thursday, June 25, 2009 12:01:19 PM(UTC)
sidfink43
I suggest you remove the agitator and inspect it and the area for damage which would cause your problem.
Here is the service manual which will take you through the process.
http://www.servicematters.com/m...ibrary/docs/16026502.pdf
Good luck, let us know what you find out.
Admiral washer squeaks during agitation (Washer Repair)
by kukayaker 10/10/2014 10:47:17 AM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Admiral washer drains, but won't spin in wash cycle (Washer Repair)
by WJG 7/19/2014 2:32:36 PM(UTC)
Admiral washer just fills (Washer Repair)
by 73buick225 3/2/2014 3:26:31 PM(UTC)
Admiral washer pls help (Washer Repair)
by nomifish07@aol.com 1/25/2014 12:46:17 PM(UTC)
Admiral washer: Cold water only on warm setting (Washer Repair)
by divemasterjt 11/20/2013 7:18:09 PM(UTC)
Admiral Washer: howling, spinning, smoking... (Washer Repair)
by Noobzilla 7/17/2013 9:03:46 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
admiral washer (Washer Repair)
by jared parsons 9/14/2012 6:33:39 AM(UTC)
by tvanloon43 7/12/2012 7:17:42 AM(UTC)
Admiral washer leak (Washer Repair)
by llimer 3/20/2012 6:10:55 AM(UTC)
Admiral washer agitates during spin cycle (Washer Repair)
by Trenchfoe 3/4/2012 6:55:13 AM(UTC)
Admiral washer agitates but wont drain. (Washer Repair)
by smitty225 2/28/2012 12:04:17 AM(UTC)
Admiral washer wont fill (Washer Repair)
by jay1437 1/15/2012 1:35:43 PM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
