The water flow is very slow coming out of the door of my refridgerator.
I checked and the ine is not kinked and it is turned on all the way. I have the line connected with one of the self tapping pieces that attach to the water line.
Any ideas? is there a way to turn up the pressure?
Thanks!
There is a mesh screen filter in the water inlet valve where the water supply connects. This can become clogged with sediment. While it's disconnected you can flush the line out and make sure the pressure is good there.
did you figure out your water pressure problem? I have the same problem on the same fridge!
