Jimh64
#1 Posted : Saturday, June 20, 2009 6:43:41 PM(UTC)
Jimh64
The water flow is very slow coming out of the door of my refridgerator.
I checked and the ine is not kinked and it is turned on all the way. I have the line connected with one of the self tapping pieces that attach to the water line.
Any ideas? is there a way to turn up the pressure?
Thanks!
woodchuckie
#2 Posted : Saturday, June 20, 2009 7:48:34 PM(UTC)
woodchuckie
There is a mesh screen filter in the water inlet valve where the water supply connects. This can become clogged with sediment. While it's disconnected you can flush the line out and make sure the pressure is good there.
rowley978
#3 Posted : Tuesday, July 21, 2009 5:08:42 PM(UTC)
rowley978
did you figure out your water pressure problem? I have the same problem on the same fridge!
bosch dishwasher has low water pressure - bad pump?? (Dishwasher Repair)
by eschnapp 5/26/2015 5:43:29 AM(UTC)
Low Water pressure at dispenser (Refrigerator & Freezer Repair)
by paul999 5/11/2014 1:57:14 PM(UTC)
Low water pressure (Dishwasher Repair)
by garyferguson56 1/9/2013 8:31:02 AM(UTC)
Washer Low Water Pressure (Washer Repair)
by TONYBETHEL 2/15/2012 4:58:41 AM(UTC)
low water pressure (Refrigerator & Freezer Repair)
by mikkidogg13 6/22/2011 10:24:28 AM(UTC)
Door dispenser Low water pressure (Refrigerator & Freezer Repair)
by bdressel@eps-inc.us 5/13/2010 7:23:52 AM(UTC)
Low Water Pressure (Refrigerator & Freezer Repair)
by Chuck123 9/20/2009 11:44:08 AM(UTC)
low water pressure mystery (Refrigerator & Freezer Repair)
by 7777biglou7777 5/24/2009 3:03:35 PM(UTC)
Low water pressure and top spinners not spinning (Dishwasher Repair)
by sfantin 2/28/2009 8:35:45 AM(UTC)
