bdressel@eps-inc.us
#1 Posted : Thursday, May 13, 2010 7:23:52 AM(UTC)
bdressel@eps-inc.us
Recently I have low water pressure at the in door water dispenser. I have changed PureSource2 filters twice and have had the county water department out to verify house pressure. All is okay. Would the water valve 4298908 be the culprit?
#2 Posted : Thursday, May 13, 2010 11:18:25 AM(UTC)
There is a screen inside the water valve which can be blocked, causing lower pressure.
- The water inlet valve Part number: AP4298908
bdressel@eps-inc.us
#3 Posted : Thursday, May 13, 2010 12:41:40 PM(UTC)
bdressel@eps-inc.us
Thanks Gene, I will check that and if encapsilated, I will replace.
#4 Posted : Thursday, May 13, 2010 8:02:45 PM(UTC)
Guest (4)
