Recently I have low water pressure at the in door water dispenser. I have changed PureSource2 filters twice and have had the county water department out to verify house pressure. All is okay. Would the water valve 4298908 be the culprit?
There is a screen inside the water valve which can be blocked, causing lower pressure. - The water inlet valve Part number: AP4298908
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There is a screen inside the water valve which can be blocked, causing lower pressure. - The water inlet valve Part number: AP4298908
Thanks Gene, I will check that and if encapsilated, I will replace.
