refrigerator freezer and compartment not cooling compressor running hot tested amps on compressor shows only 1/2 amp would bad relay cause the 1/2 amp problem.:confused: refrigerator calls for 7 amps
Check if the condenser is clean. If this is not the issue then the sealed system is low on Freon or there is a restriction in the sealed system.
