Maytag Neptune Model # MAH5500BWW Serial # A9813965EP Purchased : September 4, 2004.
HELP! water keeps filling during the wash cycle, and then it begins to over flow through the door, and continues to over fill after I push the pause and off button. And the only way to shut off the water is at the water valve, and by then water is every where.
If the water will notg stop when the machine is stopped and notg getting power than the likely problem is the valve assembly is stuck open and will have to be replaced.
You're right, when I unpluged the machine water continued to flow.
Thank You!
