Tenn47
#1 Posted : Tuesday, December 6, 2011 2:42:33 PM(UTC)
Tenn47
Maytag Neptune
Model # MAH5500BWW
Serial # A9813965EP
Purchased : September 4, 2004.
HELP! water keeps filling during the wash cycle, and then it begins to over flow through the door, and continues to over fill after I push the pause and off button. And the only way to shut off the water is at the water valve, and by then water is every where.
sidfink43
#2 Posted : Tuesday, December 6, 2011 6:24:36 PM(UTC)
sidfink43
If the water will notg stop when the machine is stopped and notg getting power than the likely problem is the valve assembly is stuck open and will have to be replaced.
Tenn47
#3 Posted : Tuesday, December 6, 2011 6:33:40 PM(UTC)
Tenn47
You're right, when I unpluged the machine water continued to flow.
Thank You!
Whirlpool MFX2571XEM0 Icemaker water overflow into ice holding bin (Refrigerator & Freezer Repair)
by Guest 8/30/2021 10:36:11 AM(UTC)
Water overflows ice maker and freezes on bottom. (Refrigerator & Freezer Repair)
by Kimlu 6/4/2016 8:43:37 AM(UTC)
water overflowing (Washer Repair)
by Josedejesus 5/2/2013 5:14:02 PM(UTC)
Maytag Neptune Water overflowing (Washer Repair)
by rboess 9/10/2012 5:58:48 AM(UTC)
Ice maker water overflow (Refrigerator & Freezer Repair)
by prniners 7/22/2012 7:47:30 PM(UTC)
Water Overflowing (Washer Repair)
by FreeGumbo 10/1/2011 7:25:34 AM(UTC)
by bravohotel 8/3/2011 12:49:17 PM(UTC)
water overflowing (Refrigerator & Freezer Repair)
by arickt 7/23/2011 6:50:06 AM(UTC)
Icemaker water overflows (Refrigerator & Freezer Repair)
by Capro22340 3/31/2011 2:25:01 PM(UTC)
water overflow in rinse cycle (Washer Repair)
by david vogel 1/6/2011 6:35:16 AM(UTC)
Icemaker - water overflows during filling cycle (Refrigerator & Freezer Repair)
by BobW484 7/15/2010 11:45:22 AM(UTC)
Water Overflows (Washer Repair)
by COUNTRTAZ 5/31/2010 10:06:33 AM(UTC)
Water Overflows And Doesn't Stop On Fill Up (Washer Repair)
by GTA17 4/18/2010 1:14:58 PM(UTC)
by ChickenShack 4/6/2010 10:31:03 AM(UTC)
Maytag Dish Washer water overflow (Dishwasher Repair)
by jim34 3/9/2010 11:51:36 AM(UTC)
