wpilotw
#1 Posted : Wednesday, June 17, 2009 8:08:27 AM(UTC)
wpilotw
washer will fill, drain, do all things but wash, took accumulator off of sump and got down to chopper and was able to turn in one direction easily but would stop in the oppisite direction, ran diag. and all worked except wash again. is this the motor bad or could it be a sensor. did not see any debree in the impeller area, please help.
#2 Posted : Wednesday, June 17, 2009 8:52:32 AM(UTC)
Replacement parts for WHIRLPOOL GU2455XTSB3 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf
If the unit is not stainless it could be a door switch, it kills the motor and the heater, see the wiring diagram upper left hand corner.
Check it with a meter to see if it is getting voltage when it should.
wpilotw
#3 Posted : Wednesday, June 17, 2009 9:04:43 AM(UTC)
wpilotw
heater is working and just pulled unit out and the motor is warm to the touch. will check capcitor and motor resistence next any other suggestiongs would be welcomed. thank you
#4 Posted : Wednesday, June 17, 2009 10:28:17 AM(UTC)
Perhaps the motor is running just the impeller is not turning.
Here is a service manual, it is for a different model but the pumps look the same. Hopefully it it be helpful.
https://secured.whirlpoo...520548/$FILE/8178022.pdf
wpilotw
#5 Posted : Wednesday, June 17, 2009 10:47:54 AM(UTC)
wpilotw
Thanks for all the help it was the motor. front bearing failed due to leake, took to a electric shop up the street and replaced bearing in motor for 7 dollars. thanks for the help!
Will not wash (Dishwasher Repair)
by Kaal35 11/21/2013 10:40:54 AM(UTC)
Kitchenaid dishwasher will not wash (Dishwasher Repair)
by strattonfamily 1/10/2013 3:47:35 AM(UTC)
Kitchen Aid Dishwasher-Drains but will not wash. Bad Panel? (Dishwasher Repair)
by wheeler459 3/15/2012 3:09:10 AM(UTC)
***Silent Partner ii will fill up with water and drain but will not wash dishes!!*** (Dishwasher Repair)
by Clemy 2/21/2012 7:39:33 AM(UTC)
Undercounter Dishwasher motor runs but will not wash. (Dishwasher Repair)
by JohnWiggins 2/13/2012 11:41:06 AM(UTC)
Whirlpool will not wash but will pump water out (Dishwasher Repair)
by M C 1/1/2012 10:31:41 AM(UTC)
fills with water but will not wash (Dishwasher Repair)
by bebopp49 12/17/2011 1:03:07 PM(UTC)
washer will spin but will not wash(agitate) (Washer Repair)
by wareagle101 8/11/2011 10:27:36 AM(UTC)
Maytag Performa will not wash after changing snubber (Washer Repair)
by bluvulture 7/13/2011 12:38:58 PM(UTC)
Matag Dishwasher will not wash (Dishwasher Repair)
by randyveach 6/10/2011 8:39:51 AM(UTC)
Whirlpool intermittently will not wash/spray (Dishwasher Repair)
by mgruebe3 5/30/2011 5:28:14 PM(UTC)
Maytag Dishwasher Will Not Wash (Dishwasher Repair)
by vidkid 12/11/2010 1:13:27 PM(UTC)
fills with water will not wash (Dishwasher Repair)
by aspzoom 7/6/2010 3:36:32 PM(UTC)
by tlark1 4/30/2010 5:49:58 AM(UTC)
Buttons not staying lit, will not wash (Dishwasher Repair)
by Pat Meehan 12/3/2009 11:46:03 AM(UTC)
