Kaal35
#1 Posted : Thursday, November 21, 2013 10:40:54 AM(UTC)
Kaal35
Quiet Partner II DU1100XTPBB,Will not wash in any mode. control appearce fucntiong correctly. Fills and starts to try to wash but only makes a buzzing noise and then stops. The machine drains fils and drains fine. It did get louder a few washes before it stopped working properly. So the control panel works it fills and drains correctly but only make a noise when in it goes to wash or in any other mode. I have checked the intakes all the way down to the copper assembly for any dabree that might clog the intake but nothing.
Appliance Ninja
#2 Posted : Thursday, November 21, 2013 12:19:31 PM(UTC)
Appliance Ninja
I suspect the main wash motor may be faulty. If you remove the lower access panel from below the door, you will be able to see the motor. Where the motor meets the plastic sump housing, do you see any water marks that would indicate it has been leaking?
Kitchenaid dishwasher will not wash (Dishwasher Repair)
by strattonfamily 1/10/2013 3:47:35 AM(UTC)
Kitchen Aid Dishwasher-Drains but will not wash. Bad Panel? (Dishwasher Repair)
by wheeler459 3/15/2012 3:09:10 AM(UTC)
***Silent Partner ii will fill up with water and drain but will not wash dishes!!*** (Dishwasher Repair)
by Clemy 2/21/2012 7:39:33 AM(UTC)
Undercounter Dishwasher motor runs but will not wash. (Dishwasher Repair)
by JohnWiggins 2/13/2012 11:41:06 AM(UTC)
Whirlpool will not wash but will pump water out (Dishwasher Repair)
by M C 1/1/2012 10:31:41 AM(UTC)
fills with water but will not wash (Dishwasher Repair)
by bebopp49 12/17/2011 1:03:07 PM(UTC)
washer will spin but will not wash(agitate) (Washer Repair)
by wareagle101 8/11/2011 10:27:36 AM(UTC)
Maytag Performa will not wash after changing snubber (Washer Repair)
by bluvulture 7/13/2011 12:38:58 PM(UTC)
Matag Dishwasher will not wash (Dishwasher Repair)
by randyveach 6/10/2011 8:39:51 AM(UTC)
Whirlpool intermittently will not wash/spray (Dishwasher Repair)
by mgruebe3 5/30/2011 5:28:14 PM(UTC)
Maytag Dishwasher Will Not Wash (Dishwasher Repair)
by vidkid 12/11/2010 1:13:27 PM(UTC)
fills with water will not wash (Dishwasher Repair)
by aspzoom 7/6/2010 3:36:32 PM(UTC)
by tlark1 4/30/2010 5:49:58 AM(UTC)
Buttons not staying lit, will not wash (Dishwasher Repair)
by Pat Meehan 12/3/2009 11:46:03 AM(UTC)
Quiet Partner II fills and drains, but will not wash (Dishwasher Repair)
by Leif S 11/14/2009 5:23:03 PM(UTC)
