gbvega
#1 Posted : Wednesday, December 19, 2007 2:19:56 PM(UTC)
gbvega
Mircowave oven will not stop running when the door is closed, eventhough no time has been programmed. Prior to this the light blub under the system went out.
#2 Posted : Wednesday, December 19, 2007 2:48:04 PM(UTC)
Does it stop if you open the door?
gbvega
#3 Posted : Thursday, December 20, 2007 4:50:44 AM(UTC)
gbvega
Yes, it stops when the door is open. gb
gbvega
#4 Posted : Thursday, December 20, 2007 4:52:11 AM(UTC)
gbvega
yes it stops when door is open
#5 Posted : Thursday, December 20, 2007 12:21:18 PM(UTC)
Most likely the problem with the microwave is a bad PCB (printed circuit board).
- The part number for the PCB is AP3191409
- Here are the break down diagrams for the GE microwave Model JVM1630WB004
Good luck.
