gbvega
#1 Posted : 17 years ago
gbvega
Mircowave oven will not stop running when the door is closed, eventhough no time has been programmed. Prior to this the light blub under the system went out.
#2 Posted : 17 years ago
Does it stop if you open the door?
gbvega
#3 Posted : 17 years ago
gbvega
Yes, it stops when the door is open. gb
gbvega
#4 Posted : 17 years ago
gbvega
yes it stops when door is open
#5 Posted : 17 years ago
Most likely the problem with the microwave is a bad PCB (printed circuit board).
- The part number for the PCB is AP3191409
- Here are the break down diagrams for the GE microwave Model JVM1630WB004
Good luck.
