Mircowave oven will not stop running when the door is closed, eventhough no time has been programmed. Prior to this the light blub under the system went out.
Does it stop if you open the door?
Yes, it stops when the door is open. gb
yes it stops when door is open
Most likely the problem with the microwave is a bad PCB (printed circuit board). - The part number for the PCB is AP3191409 - Here are the break down diagrams for the GE microwave Model JVM1630WB004Good luck. Gene.
