i am having trouble with the dryer running for 5-10 minutes then shutting off. I have cleaned all the vents i have replaced the motor.. The dryer gets hot but stops. I then unplug it and let it cool for a while then it runs for 3-4 minutes and shuts back off. please help
This is somewhat of a mystery.
I would check the heating element for any shorting out, (test it for continuity and for grounding) and if this is not the problem I would replace the thermal cut-off and thermostats.
That should do it,(unless your replacement motor is bad) let us know how it works out.
