rex4634jq0
#1 Posted : Thursday, June 11, 2009 6:48:37 AM(UTC)
rex4634jq0
i am having trouble with the dryer running for 5-10 minutes then shutting off. I have cleaned all the vents i have replaced the motor.. The dryer gets hot but stops. I then unplug it and let it cool for a while then it runs for 3-4 minutes and shuts back off. please help
sidfink43
#2 Posted : Saturday, June 13, 2009 3:48:00 PM(UTC)
sidfink43
This is somewhat of a mystery.
I would check the heating element for any shorting out, (test it for continuity and for grounding) and if this is not the problem I would replace the thermal cut-off and thermostats.
That should do it,(unless your replacement motor is bad) let us know how it works out.
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
