boprince
#1 Posted : Sunday, June 7, 2009 1:25:54 PM(UTC)
boprince
My oven is not heating. Have determined that it is one of the heating elements. How do I know which one to replace?
woodchuckie
#2 Posted : Sunday, June 7, 2009 4:42:53 PM(UTC)
woodchuckie
If it doesn't heat when you select bake, replace the bottom one.
If it doesn't heat when you select broil, replace the top one.
alron2
#3 Posted : Monday, June 8, 2009 9:19:05 AM(UTC)
alron2
Before I bought a new element I would make sure I had 230 volts a t the element connection. Problem could be a broken or loose wire or a bad relay.
JMO
Ron
#4 Posted : Monday, June 8, 2009 9:48:55 AM(UTC)
Replacement parts for WHIRLPOOL GBS307PRB01 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208301758.pdf
First check that you have 240 volts going to the unit.
If you do not have a meter turn the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker, the control only requires half the line (120 volts) not the full 240 volts that the elements require.
Note that the tech sheet says both elements should be on during preheat.
Note that there is a thermal fuse in line with both elements.
Check it with a meter, should be 0 ohms.
Another possibility would be that the Double Line Break Relay is not closing.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
