cktab
#1 Posted : Tuesday, November 22, 2011 6:39:43 PM(UTC)
cktab
Hi all newbie here just looking for a little help with our old beasty, today it just started to not add cold water to the wash cycle on any settings only hot. the only spot it will add cold is on any rinse setting. so now we half fill it on a rinse setting, turn to a wash setting and let it finish adding hot. rinse, wash and spin are ok. any ideas? thanks
#2 Posted : Wednesday, November 23, 2011 5:00:59 AM(UTC)
I cannot find any info on the given model number.
Tried AppliancePartsPros and the Whirlpool sites.
Please check it.
Model Number Locator
Since you can get cold water for rinse the cold valve and cold water supply is OK so that leaves whatever is controlling the valve.
If the unit has a temperature sensing system then that is the probable cause.
They are more trouble than they are worth.
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 4/2/2022 10:43:24 AM(UTC)
Kitchenaid clothes washer (Washer Repair)
by 76 Terra 1/24/2022 10:05:31 AM(UTC)
Clothes Washer (Washer Repair)
by jogrodz 4/2/2018 6:36:28 AM(UTC)
clothes washer only leaks when filling (Washer Repair)
by elijahfischer 8/22/2013 7:06:46 AM(UTC)
Maytag clothes washer (Washer Repair)
by fnolen 7/21/2013 3:04:54 PM(UTC)
Kitchenaid clothes washer won't spin without a push (Washer Repair)
by dlunde 5/29/2013 5:23:00 PM(UTC)
GE Clothes washer won't advance to wash cycle (Washer Repair)
by Zog 2/11/2013 4:33:01 PM(UTC)
by louis Dionise 12/14/2012 10:40:32 AM(UTC)
Clothes Washer Lint Issue (Washer Repair)
by kenmoregator 11/30/2012 3:01:10 AM(UTC)
by duffybpp 8/30/2012 3:28:44 AM(UTC)
Whirlpool Clothes Washer (Washer Repair)
by DirtyClothes1 7/7/2012 4:01:42 PM(UTC)
lint clothes washer (Washer Repair)
by paulmars 3/16/2012 4:21:12 PM(UTC)
Whirlpool Clothes Washer time won't advance (Washer Repair)
by djaco4749 3/9/2012 8:11:44 AM(UTC)
Clothes Washer won't spin clothes dry (Washer Repair)
by JCHD 1/26/2012 7:09:42 AM(UTC)
