cktab
#1 Posted : 13 years ago
cktab
Hi all newbie here just looking for a little help with our old beasty, today it just started to not add cold water to the wash cycle on any settings only hot. the only spot it will add cold is on any rinse setting. so now we half fill it on a rinse setting, turn to a wash setting and let it finish adding hot. rinse, wash and spin are ok. any ideas? thanks
#2 Posted : 13 years ago
I cannot find any info on the given model number.
Tried AppliancePartsPros and the Whirlpool sites.
Please check it.
Model Number Locator
Since you can get cold water for rinse the cold valve and cold water supply is OK so that leaves whatever is controlling the valve.
If the unit has a temperature sensing system then that is the probable cause.
They are more trouble than they are worth.
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 3 years ago
clothes washer don't work, troubleshooting manual wtw5500xw0 cabrio (Washer Repair)
by paulmars 3 years ago
Kitchenaid clothes washer (Washer Repair)
by 76 Terra 3 years ago
Clothes Washer (Washer Repair)
by jogrodz 7 years ago
clothes washer only leaks when filling (Washer Repair)
by elijahfischer 12 years ago
Maytag clothes washer (Washer Repair)
by fnolen 12 years ago
Kitchenaid clothes washer won't spin without a push (Washer Repair)
by dlunde 12 years ago
GE Clothes washer won't advance to wash cycle (Washer Repair)
by Zog 12 years ago
by louis Dionise 12 years ago
Clothes Washer Lint Issue (Washer Repair)
by kenmoregator 12 years ago
by duffybpp 13 years ago
Whirlpool Clothes Washer (Washer Repair)
by DirtyClothes1 13 years ago
lint clothes washer (Washer Repair)
by paulmars 13 years ago
Whirlpool Clothes Washer time won't advance (Washer Repair)
by djaco4749 13 years ago
Clothes Washer won't spin clothes dry (Washer Repair)
by JCHD 13 years ago
