whirlpool duet GHW9100LW1 - Powers up will not start...led flashes on wash cycle selector..Downloaded the job aid :
1.Completes entire diagnostic test ok
2. Checked continuity on all components: door lock solenoid had high reading..replaced lock assembly.
3. Reseated all connections.
still will not start
What next? CCU or Touch pad Assembly
Well, you have already done what I would recommend, so I think you should go through the trouble shooting on the CCU in the manual. Here is the manual. https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdfGood luck, and let us know what you find out. I am guessing it will be the CCU because like the butler in the mystery stories, it almost always is.
I cannot run the diagnostic test i followed the directions and the time for 2 min just blinks...any thoughts?
I have the same issue did you solve your issue and if you did what should I do?
Mikeheff
Please start a new thread and post your model number and a more detailed description of your problem and someone should be able to help you.
