jfinchum
#1 Posted : Saturday, June 6, 2009 1:55:38 PM(UTC)
jfinchum
whirlpool duet GHW9100LW1 - Powers up will not start...led flashes on wash cycle selector..Downloaded the job aid :
1.Completes entire diagnostic test ok
2. Checked continuity on all components: door lock solenoid had high reading..replaced lock assembly.
3. Reseated all connections.
still will not start
What next? CCU or Touch pad Assembly
sidfink43
#2 Posted : Sunday, June 7, 2009 5:14:33 PM(UTC)
sidfink43
Well, you have already done what I would recommend, so I think you should go through the trouble shooting on the CCU in the manual.
Here is the manual.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
Good luck, and let us know what you find out. I am guessing it will be the CCU because like the butler in the mystery stories, it almost always is.
adidaalaska2001
#3 Posted : Saturday, June 29, 2013 12:55:58 PM(UTC)
adidaalaska2001
I cannot run the diagnostic test i followed the directions and the time for 2 min just blinks...any thoughts?
Mikeheff
#4 Posted : Wednesday, August 13, 2014 11:44:02 AM(UTC)
Mikeheff
I have the same issue did you solve your issue and if you did what should I do?
sidfink43
#5 Posted : Thursday, August 14, 2014 5:29:37 AM(UTC)
sidfink43
Mikeheff
Please start a new thread and post your model number and a more detailed description of your problem and someone should be able to help you.
Guest (4)
Whirlpool Duet won't start cycle or unlock door (Washer Repair)
by nine 2/20/2015 2:50:58 PM(UTC)
Whirlpool Duet won't start (Dryer Repair)
by Squelch 2/14/2013 9:02:21 AM(UTC)
