Ziggy
#1 Posted : Thursday, June 4, 2009 4:52:48 PM(UTC)
Ziggy
Was washing some clothes, when my wife walked in and said the washer is making a fast clicking noise but wont't spin , however the water does drain, I tried running it through the cycle and noticed it hardly wants to agitate since it stoped spining, but everything else works,
How do you remove the cabinet around the washer, I'm thinking it might the cuppling ? if so any instructions would be apprecciated. Thank You:confused:
applianceman
#2 Posted : Friday, June 5, 2009 5:57:39 AM(UTC)
applianceman
It does sound like the coupling.
To remove the cabinet, first disconnect power.
Then hinge up the control panel by removing the two screws on each end (some are on the back some on the front and some you have to remove a cover to see the screws).
Once the control panel is up remove the two metal clips on each side of the cabinet.
Next unplug the wire plug in the middle of the cabinet.
Then the cabinet should hinge over toward you and off.
To get to the coupling you must remove the pump and the motor both are held on with clips.
Whirlpool Washer Not Running Repair Guide
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Machine goes through cycle but won't spin (Washer Repair)
by Guest 9/12/2021 10:04:44 AM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Pumps but won't spin or drain (Washer Repair)
by Guest 6/21/2021 2:45:48 PM(UTC)
SQ Washer Tub Won't Spin Still After Initial Troubleshooting (Dishwasher Repair)
by vamazzeo 4/16/2021 10:00:33 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
GE Top Load washing machine, won't spin & won't stop cycling (Washer Repair)
by Stefano31 9/29/2020 3:01:44 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
Won't spin fast - only slow (Washer Repair)
by Machine_Slo 1/6/2020 9:16:58 PM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
