Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My Whirlpool Ultimate Care II washing machine will load up with water but will not start the motor for spinning, agitating, and draining. I replaced the lid switch which was broken but still wouldn't work. Turns out the capacitor dropped out of its casing and so it was hanging on only by the wire connection. Over time, one of the wires had cut through insulation and wires, thus killing the motor.
Here's the hard part I can't figure out: I cannot find this female quick disconnect terminal that I need in order to fix this part. Thoughts?
