gas dryer lites OK but will not get hot enough to dried load. replaced temp control switch but did no give me enough heat. can u suggest anything else I should check and what sequence. tumbler works, door switch also works fires up on high but and goes off shortly there after any suggestions? James Hazley desperate.
Originally Posted by: James Hazley gas dryer lites OK but will not get hot enough to dried load. replaced temp control switch but did no give me enough heat. can u suggest anything else I should check and what sequence. tumbler works, door switch also works fires up on high but and goes off shortly there after any suggestions? James Hazley desperate. gas dryer lites OK but will not get hot enough to dried load. replaced temp control switch but did no give me enough heat. can u suggest anything else I should check and what sequence. tumbler works, door switch also works fires up on high but and goes off shortly there after any and reigniting ,suggestions? James Hazley desperate.
