James Hazley
#1 Posted : Thursday, June 4, 2009 3:14:36 PM(UTC)
James Hazley
gas dryer lites OK but will not get hot enough to dried load. replaced temp control switch but did no give me enough heat. can u suggest anything else I should check and what sequence. tumbler works, door switch also works fires up on high but and goes off shortly there after any suggestions? James Hazley desperate.
James Hazley
#2 Posted : Thursday, June 4, 2009 3:30:34 PM(UTC)
James Hazley
Model Number: whiripool LGR7646JQO Brand: Whirlpool Age: 1 - 5 years
gas dryer lites OK but will not get hot enough to dried load. replaced temp control switch but did no give me enough heat. can u suggest anything else I should check and what sequence. tumbler works, door switch also works fires up on high but and goes off shortly there after any and reigniting ,suggestions? James Hazley desperate.
GAS DRYER repair (Dryer Repair)
by djralo 4/24/2012 11:24:56 AM(UTC)
gas dryer repair (Dryer Repair)
by allijackjackalli 1/29/2012 11:04:06 AM(UTC)
Gas dryer repair (Dryer Repair)
by kel4dolphins 10/7/2011 5:03:15 AM(UTC)
Natural Gas Dryer Repair (Dryer Repair)
by LAL 7/27/2009 6:48:47 PM(UTC)
propane gas dryer repair (Dryer Repair)
by SusieE 6/30/2009 8:57:10 AM(UTC)
by cackerman 1/9/2009 2:34:06 PM(UTC)
