Dblaise
#1 Posted : Monday, June 1, 2009 9:59:08 AM(UTC)
Dblaise
My dryer quit running. I assumed it was the timer motor and I replaced that. That was not the problem. Would the next logical part to check be the thermal fuse. How do you get to it? Where is it located?
sidfink43
#2 Posted : Tuesday, June 2, 2009 4:24:25 PM(UTC)
sidfink43
Hi Dblaise
Sorry the timer did not fix it.
Here is the service manual which will show the location of the electrical components you will want to test.
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
Good luck and let us know what you find out.
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Alternate solution for control panel thermal fuse? (Oven Repair (including Ranges and Cooktops))
by mjrat 7/21/2015 1:57:46 PM(UTC)
Thermostat or Thermal Fuse??? (Dishwasher Repair)
by jmillsp 11/13/2014 9:43:51 AM(UTC)
Where to purchase a GE Dishwasher thermal fuse? (Dishwasher Repair)
by 0101kgkg 6/7/2012 3:15:31 AM(UTC)
Old Inglis Dryer-No Thermal Fuse? (Dryer Repair)
by volvik 1/1/2012 3:47:27 PM(UTC)
Where is thermal fuse? (Dryer Repair)
by mnumbers 12/14/2010 6:48:43 PM(UTC)
Replace high limit thermostat a or cycling thermostat along with the thermal fuse? (Dryer Repair)
by BrassMonkey 6/17/2010 12:35:31 AM(UTC)
Heating element or thermal fuse? (Dishwasher Repair)
by wortonmt 4/5/2010 7:12:55 PM(UTC)
Kenmore won't turn on: where is the thermal fuse? (Dryer Repair)
by omnipheasant 5/22/2008 9:55:31 AM(UTC)
2nd blown thermal fuse??? (Dryer Repair)
by Cari 11/25/2007 3:31:55 PM(UTC)
bypass thermal fuse? (Dryer Repair)
by markus 11/14/2007 10:35:14 AM(UTC)
Where's the thermal fuse? (Dryer Repair)
by deburrito 10/12/2007 5:51:16 PM(UTC)
