The Lower spray arm assembly on this dishwasher has two metal plates on the under side that deflect the water upward. The problem is that they keep coming loose. After reattaching them a few hundred times, the plastic studs that hold them in place are now broken off. I cant figure out how to remove the spray arm so that I can replace the whole assembly. Are there any special tools needed to do this?
