Ms. Irish
#1 Posted: : Thursday, December 13, 2007 11:33:05 AM(UTC)
Ms. Irish
I am hoping to get my dryer fixed and that someone will know what the answer is. This is a Gas Dryer.
Dryer Type: DWSR-NAT-1206006CV22
Dryer will not get very warm. It takes two 80 cycles to get clothes dry and it will be mostly air dried. If you put in clothes for the 20 minute or less cycle they will get warm but not HOT.
I have pulled the dryer from the wall and checked the silver hose for clogs and it is all clean.
A couple of months ago my gas was shut off and since then I have been having troubles. Maybe coincidense? But I did see the gas guy check to see if the thing was lit through the little plug hole. :confused:
#2 Posted : Friday, December 14, 2007 10:31:13 AM(UTC)
Most likely the problem with your dryer are a bad coils on the gas valve.
The gas valve coil kit
UserPostedImage
- The part number for the gas valve coil kit is AP2150379
In order to get access to replace the gas valve coils you have to remove the front panel.
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Kenmore Elite HE3 gas heating problems (Dryer Repair)
by karl1970 12/24/2014 6:39:08 PM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
Oven preheating problems (Microwave Repair)
by groucho 5/24/2012 1:38:24 PM(UTC)
Frigidaire Gas Oven FGFL88ACA Heating Problems (Oven Repair (including Ranges and Cooktops))
by mzdrati 4/10/2012 6:30:18 PM(UTC)
Kenmore 500 series dryer timer/heating problems (Dryer Repair)
by Davy99 4/1/2012 7:23:12 AM(UTC)
GE XL44 Gas Convection Oven - heating problems (Oven Repair (including Ranges and Cooktops))
by MaryMcK 9/1/2010 10:27:37 AM(UTC)
Roper Heating problems (Dryer Repair)
by bugspray34 9/30/2009 7:15:14 PM(UTC)
heating problems, no heat (Dryer Repair)
by ddnguyen06 7/8/2009 3:10:40 PM(UTC)
by ddnguyen06 7/8/2009 3:04:42 PM(UTC)
by ddnguyen06 7/8/2009 3:01:02 PM(UTC)
Old Roper oven heating problems (Oven Repair (including Ranges and Cooktops))
by oven delima 12/5/2008 7:22:36 AM(UTC)
dryer starting and heating problems (Dryer Repair)
by jbcholding 3/14/2008 11:28:59 AM(UTC)
