my electric dryer have no heat. I checked heating element and still good. please help.:confused:
I assume you checked the heating element with a meter, so you are now ready to check some other things.
1. Make sure you have 240 volts getting to the connection block. An make sure your connections are tight (after you unplug the machine!!)
2. Next check your thermal fuse for continuity.
3. Next check your thermostats to make certain they are closed.
If all this does not do the job, go back to the element and make sure it is not broken or grounded.
Good luck, these should get it done for you.
