dcash
#1 Posted : Tuesday, May 26, 2009 4:46:47 PM(UTC)
dcash
My kitchen aid refrigerator has had four thermostats replaced and the lower portion of the unit continues to freeze up. I have had a tech come out and did a service call and he replaced the first three and they would work for a while and go back to freezing. I replaced the thermostat last friday and it worked until today. What else should i check on the unit to keep the ref part from freezing up?
woodchuckie
#2 Posted : Tuesday, May 26, 2009 4:53:45 PM(UTC)
woodchuckie
I would think that the tech would check but just to eliminate this as a problem-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap(damper) you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
