My kitchen aid refrigerator has had four thermostats replaced and the lower portion of the unit continues to freeze up. I have had a tech come out and did a service call and he replaced the first three and they would work for a while and go back to freezing. I replaced the thermostat last friday and it worked until today. What else should i check on the unit to keep the ref part from freezing up?
I would think that the tech would check but just to eliminate this as a problem- The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap(damper) you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
