ladbroke
#1 Posted : Tuesday, December 11, 2007 8:43:12 PM(UTC)
ladbroke
The last 2 times I used the oven, I turned the oven to bake on 350 degrees and the oven took about 5 minutes for the burner to go on. Both times there was a slight but definite smell of gas. After the burner went on, the oven worked fine and the gas odor disappeared. I am prepared to call a stove repairman, but am wondering if I can do anything to fix it.
#2 Posted : Wednesday, December 12, 2007 10:09:02 AM(UTC)
Most likely the problem with your oven is a bad bake igniter (#18 on the gas control break down diagram).
Replacing the igniter should solve the problem.
If you know how to use a simple hand tools - you can easy do it yourself.
- The part number for the bake igniter AP2150412
- Here are the break down diagrams for the Tappan range Model 30-3982-00-01
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 1/30/2017 5:34:03 AM(UTC)
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 10/29/2013 10:55:04 AM(UTC)
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 1/1/2011 1:09:12 PM(UTC)
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 12/16/2007 12:03:05 PM(UTC)
