I went to turn om my Matag MDG8400AW dryer and it would not start. The damp light came on, but the dryer did not start tumbling or warm up. I turned the knob to the "extended tumble" position and the dryer starts up and tumbles (no heat). What's wrong? What steps should I go through to diagnose the problem and find the bad component? I tested the continuity on the ignitor and thermal fuse. Haven't found the problem yet. Need Help! Jim
It turned out to be burned contact switches in the timer. Thanks for the service manual.
Glad you found the problem, and thanks for updating us. A lot of folks view this site and your posting.
Now I noticed another problem. The new timer stays in the same position as the dryer runs, and the dryer does not shut off when the clothes are dry. Is the new timer bad? Shouldn't it rotate itself to the off position as time goes by?
Does this happen on timed dry, or automatic on on both?
Good idea to try that. Yes the timer does advance during timed dry. Did something go wrong with the intelidry? It was working before the original timer went bad.
In automatic mode the moisture sensor prevents the timer motor from running until the clothes are nearly dry. Check all the wires coming into the timer and see if you can find the problem.
Good luck.
