washer fills with water then nothing,I checked the door switch seems ok.
Here's a lid switch for your machine. To thoroughly test it, you'll need to do a continuity test on it. First, however, try the machine in other cycles. Also try it in just a spin cycle. This will help determine whether your problem arises out of a bad timer. Part number: AP3100003
