george248
#1 Posted : Monday, October 31, 2011 7:37:23 AM(UTC)
george248
Hello. I have an Estate washer model # TAW700JQ1 that stopped working yesterday. I went to empty the washer and it was filled with water. The timer was on off indicating the cycle completed but did not drain. I replaced the lid switch earlier this year so I don't suspect that.
At this point the washer does not do anything (fill, agitate, spin, drain). When I turn the knob on the timer, I can hear a faint "ticking" but that is it.
Any ideas?
Thanks,
George
george248
#2 Posted : Monday, October 31, 2011 5:52:43 PM(UTC)
george248
Problem solved. One correction to my first post is that water did actually come out in the rinse cycles (I forgot I turned the water off:rolleyes: )
The old sock in the pump routine:
UserPostedImage
UserPostedImage
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
Whirpool Estate..Bad Timer? (Washer Repair)
by APPLIANCEDUDE1972 9/20/2014 9:11:27 PM(UTC)
by jtvolk 10/11/2013 5:36:23 PM(UTC)
bad timer? (Washer Repair)
by jay99 7/16/2009 2:22:39 PM(UTC)
Bad timer? (Washer Repair)
by cager 5/15/2009 6:21:50 AM(UTC)
Washer won't drain or spin, Bad timer? (Washer Repair)
by myrdynn 12/30/2007 1:50:32 PM(UTC)
