cager
#1 Posted : Friday, May 15, 2009 6:21:50 AM(UTC)
cager
First wash cylcle ends. Machine starts to drain but drains only for 10-15 seconds. Cycle stops and tub is refilled with water. The tub is not completely drained of water and soap. Wash cycle begins again and runs normally to the end. Problem is the soap is still on clothes at the end. Thanks for the help.
#2 Posted : Friday, May 15, 2009 2:07:06 PM(UTC)
Sounds like the problem is a bad timer.
- The part number for the timer is AP3763295
Here are the breakdown diagrams and Replacement parts for AMANA LW8253W | AppliancePartsPros.com
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
Whirpool Estate..Bad Timer? (Washer Repair)
by APPLIANCEDUDE1972 9/20/2014 9:11:27 PM(UTC)
by jtvolk 10/11/2013 5:36:23 PM(UTC)
Bad timer? (Washer Repair)
by george248 10/31/2011 7:37:23 AM(UTC)
bad timer? (Washer Repair)
by jay99 7/16/2009 2:22:39 PM(UTC)
Washer won't drain or spin, Bad timer? (Washer Repair)
by myrdynn 12/30/2007 1:50:32 PM(UTC)
