I had no heat so I replaced the ignitor. Still no heat. Dryer runs otherwise and I have gas at the burner assembly. Any suggestions?
Check the little white fuse at the rear of the dryer, If its open, replace it!!!:)
Just to add my 2 cents... The thermal fuse is shown as #7 on the diagram. Gene.
