cmareck
#1 Posted : Monday, May 11, 2009 5:55:08 PM(UTC)
cmareck
the washer will fill,wash/agitate but won't spin..I have tried moving the controls to other cycles but no spin in any of them at a loss and not knowing if I need to start looking for a new one or if the repair for this one is not as costly..thanks for any help
sidfink43
#2 Posted : Tuesday, May 12, 2009 3:55:43 PM(UTC)
sidfink43
Hi Cmareck
The first thing you want to do is to by pass the lid switch to see if that is the problem.
To do this you need to take out the two screws that hold the console to the cabinet and then flip up the console. You will see a plastic connector coming from the console and going into the cabinet. Disconnect this and take an insulated wire and place it in the two outside holes of the connector coming from the console. This will by pass your lid switch.
Plug the washer back in (you did unplug it right!) and turn the timer to a spin cycle and engage it. If the washer spins you need to change out the lid switch.
Good luck and let us know how it turns out.
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
