Code appeared on my initial service mode. Checked my pressure switch connection, things looks physically ok, even when I tried to suck through the tube...it opens the line. Tried to spin & heard my drain pump sloshing the water but not a whole lot will come out. Time display is not progressively counting down but will go up a notch then down a bit.
Pls. advice and where can I buy the part?:confused:
It is hard to say based on the info provided, but the place to start is with the drain pump. You need to check to see if it is getting current.
If you want to replace it, go to the parts section of this Site and insert your model number. You will be taken to exploded views of your machine along with the part number. You can use that info to get parts.
