The oven ingnitor glows bright red, but the safety valve won't open up unless I tap on it. The broiler works fine. I replaced the valve (part #AP2138239), but the same thing happens. The sticker on the valve says "do not apply 120 volts to this valve", but the shorter lead coming from the ignitor to the valve has 117 volts when the oven selector switch is calling for heat, and 2 volts when it's off. Are we talking a new module and ignitor; and possibly another new safety valve if I fried this one? :( :confused: :mad: :rolleyes: :eek:
