Discuss
Gas Oven not burning
 in
I have a Caloric gas double oven model # RWS214UWW, MFG # P1132442NWW. Problem I am having is the oven will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Oven not burning
  #1 (permalink)
Old 10-13-2007, 11:00 AM
C5Steve C5Steve is offline
Junior Member
C5Steve is on a distinguished road
Default Gas Oven not burning
Model Number: RWS214uww   Brand: Caloric   Age: More than 10 years
I have a Caloric gas double oven model # RWS214UWW, MFG # P1132442NWW. Problem I am having is the oven will not start, the ignighter glows red but burner will not fire up and I do not smell any gas, what could the problem be? Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-14-2007, 12:50 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi C5Steve
Most likely the problem with your oven is a bad igniter and it has to be replaced. The new igniter comes without a bracket. You should use the bracket from the old igniter.
- The part number for the new igniter AP2934763
- Here are the break down diagrams for the Caloric oven Model RWS214UWW
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-14-2007, 04:33 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi C5Steve
Good luck.
Thanks for the info Gene, but when I turn the stove on the igniter glows a bright orange so wouldn't that mean it is working? Also I don't smell any gas while I wait.
  #4 (permalink)
Old 10-14-2007, 05:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi C5Steve
The igniter is wired in series with the burner valve. When the thermostat calls for heat, line voltage is applied to the circuit. As the igniter begins to glow, the current increases. The current flow causes the valve to open when the igniter becomes bright red (almost white). Flat igniters operate from 3.2 to 3.6 amps. In your case the current is less then 3.2 amps and even it does glow it does not open the gas valve.
__________________
  #5 (permalink)
Old 11-04-2007, 08:13 AM
Junior Member
Default
Gene,
I bought the igniter and now trying to install it. I have the igniter removed from the brackets but the wires do not pull through, should I be trying to pull harder? My oven is a in wall unit, do I have to take the oven out of the wall to get to the wires? Thank you
Steve
  #6 (permalink)
Old 11-05-2007, 10:30 AM
Junior Member
Default
Gene,
Steve
  #7 (permalink)
Old 11-05-2007, 10:44 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve
If you can not pull wires through, do not use an excessive force. It is better to remove the oven from the cabinet.
Before you do it, do not forget to disconnect the power, shut off the gas to the oven and disconnect the gas line from the oven.
__________________
  #8 (permalink)
Old 11-05-2007, 12:13 PM
Junior Member
Default
Hi Steve
Thanks, yes I figured that out and I was in the process of installing the igniter and I broke the element . So now ordering another and try again next week. Thanks again
  #9 (permalink)
Old 11-05-2007, 12:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burning smell from inside? nanner5953 Dryer Repair 1 08-21-2007 03:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
